Stefonius
Aug 08, 2013Explorer
spcorvette wrote:Hot glue and JB Weld will loosen up with matches or toothpicks because they do not soak into the wood. Carpenter's glue is the better choice because it's water based and will penetrate the wood and cause it to swell just enough.
I have used the wooden matches seal with Hot-Melt glue, but they tend to loosen up.
Maybe a combination of JB Weld and Matches will do the trick. I will keep you posted.
Terry
38,782 PostsLatest Activity: Sep 10, 2026
