enblethen wrote:
50 RV circuit is exactly the same as the current range wiring. It is 120/240 volt four wire.
Stepdad: if you have a 50 to 30 adapter it should provide power to the whole rig with reduced amps. You can even get the 30 to 15/20 amp adapter and be able to run light loads like refer and battery charging system.
Hope you are going to have enough time to enjoy the rig!
Thank you my friend. I was wondering about that. Even if I don't have 50 or 30 amps yet I can reduce it down to at least charge the batteries.
~Thanks again, John
