91tiger's avatar
91tiger
Stupid Question on Generators
Just starting to explore moving up from a class B to class C. Do most of the class C generators run off propane or gasoline? Seems like running off of gasoline from the unit's fuel tank would be the way to go. If a unit comes with a propane generator, would it be easy to switch out for a gasoline model of the same size?
The Coachmen Freelander specs say it is a "gas" generator. I assume that is gasoline not LP Gas?
  • Most class "C"'s are built on a cutaway Ford or the Chevrolet chassis, very few are Diesel, the majority are gasoline and the generators are also powered with gasoline, having a separate propane tank is a waste of space and weight, specially today with slide outs that eat into the carrying capacity of the units.
    Diesel "C"'s tend to be very loud in the cabin since part of the engine and all of the transmission are in a very thin dog house next to the occupants, I would not like the noise and racket next to me for several hours.
    The generator taps into the chassis fuel tank and is designed to stop delivering fuel to the generator when the fuel tank reaches 1/4 full, this is done to prevent the tank being completely emptied by running the generator.
    If you get one of the big "C" units built on a cargo carrying chassis then you have the option of having more fuel tanks since the chassis will handle more weight.
    navegator
  • The only Class C's with propane generators are those with diesel engines. I've had both and propane burns cleaner. Since I have solar now, I hardly ever need to use my generator. :)
  • Most Class C motorhomes have Gasoline generators if chassis engine is gas. LP generators can be found in some Diesel Class C motorhomes. The Diesel option cost more than the LP model. If you do not plan on doing a lot of boondocking the LP option is OK.
  • Most are gasoline, very few are propane.
    Yes that would be gasoline.
