DrewE
Oct 04, 2018Explorer III
Will you be at a campground with a dump station or hookups? If so, you could just dump your holding tanks before going to bed each night that is shaping up to be cold.
I also suspect you'd be fine without doing anything, but I also won't be around to worry about the mess if that proves to be incorrect. RV antifreeze wouldn't do all that much in the holding tank unless you put a whole lot down. I would suggest rock salt as a better antifreezing agent to use in this case. Even if things froze, though, I don't think it's too likely you'd suffer holding tank damage with your setup. If you have plumbing runs exposed underneath for the fresh water system, they would be a much greater concern for me.
