bobndot
Oct 04, 2018Explorer III
I have never had a problem at those mid 20's temps with exposed tanks on my TC's as well as my TT's.
Use a hair dryer to thaw the dump valve in case it sticks, most of the time that valve will be the first thing to let you know that it's cold out here whizbang.
As said the warm water in those tanks will take a long enough time to freeze when the daytime temps are above freezing. Don't forget to remove your outside water hose at night, use your holding tank and pump for water.
