whizbang
Oct 04, 2018Explorer II
Good advice guys. Thanks.
We changed our plans a bit... I will fish different rivers.
The weather above I90 is forecast-ed at 28 - 29 degrees F instead of 21 degrees F. 29F is no big deal with daytime highs in the low 40's.
When I empty the tanks, I will start them off with 2 gallons of antifreeze. By the time the antifreeze is diluted enough to stop working, the volume of fluid in the tanks should be enough to prevent freezing.
Next summer, I will install 12 volt heat strips so this is less of an issue.
Thanks!!!
I'm not worried about the valves since the hose couplings are so short.
Thanks!!!
