ron_dittmer
Oct 05, 2018Explorer III
I wonder how hard it would be to locate and install waste tank bottom-mount heating pads and made-to-fit insulation blankets. I think many class C's use the same size waste tanks given how well they fit and attach to the frame of an E350 & E450. If the tanks are a standard item, then the bottom-mount heating pads and insulation blanks on our rig may also be standard off-the-shelf items. Just buy and install, add a 12V supply with an on/off switch and you will be well prepared for much colder temps.
Our Phoenix Cruiser 2350 two waste tanks are 35 gallons and 23 gallons. Phoenix USA uses the same exact tanks on all 9 of their models going back at least 11 years now. The floor plan dictates which tank is gray and which tank is black. Phoenix heats and insulates all tanks identically, I assume with purchased kits. CLICK HERE to see a few pictures of our insulated waste tanks. The insulation blankets appear to be custom-fit.
What is the tank capacities the rest of you all have on your brand rigs?
