SDcampowneroper
Oct 13, 2018Explorer
time2roll wrote:cold wont hurt it, it just wont cool . You need to close off the lower vents some or all to maintain an above freezing to 100degree f temp on the back outside of the fridge.pianotuna wrote:Can the cold actually damage the fridge or does it just stop working while it is cold?
You will need to protect the fridge.
Is there a standard range of operating temperature?
You will find the vent , a large rectangular pane outside. Somehow close the airflow either with a plastic bag held inside the vent, by the vent, or my fav and choice is foam pipe insul. cut and tucked in to the grille. You can add or remove a piece as the weather changes.
