xtal_01's avatar
xtal_01
suburban furnace tripping on high temp
Hello,
I have a Bounder RV with a year old Suburban SF-35Q furnace ... about a weeks run time on it.
A few weeks ago I replaced the propane regulator.
At the time, I noticed the unit was tripping out ... I suspected on high temp.
I was also having an ignition problem (would not lit after ignition).
So, I bough a Dinosaur board. This fixed the ignition problem.
Now I can say for certain, the safety circuit is tripping (board has an indicator).
I tested the sail switch ... seems fine.
I replaced the high temp switch ... we are still tripping out.
So, I pulled the ducting off the rear port on the furnace .... ran it with no line ducting on it ... just dumped the warm air into the basement ... worked. Ran for an hour with no trip.
So, I put hard piping (house type galvanized steel) onto the furnace ... just some straight and 4 bends ... this is the line that comes across the RV and into the washroom. there is a small Tee to bleed air below ... I left inline as it was.
Trips out again on high temp!
Tried pulling two of the duct lines off the plenum coming off the top of the furnace ... still trips out
Tried opening one of the other side ports on the furnace ... still trips out.
I did put a manometer on the regular ...
old ... 12" wc static ... 10 - 11 while running (just bleed some off as it is in the shop and not on the furnace).
New 15" WC static ... 13" when the furnace is on.
motor is a constant 6.5 amps
It even tripped with the outside cover off so I now it is not the return air.
OK, I am stumped ... I have been at this for days standing in the snow.
I did everything I can think off ... I checked with the factory. They said it should not be tripping the high temp switch.
I am getting desperate ... suppose to be leaving on a trip this weekend.
Any suggestions ?????
Thanks .... Mike
  • Well yes and now on the motor .... I assume it ran correctly but maybe I just never noticed that the burner came on and off while the furnace was running. I really only noticed it after I changed the regulator. So I am wondering if a low pressure regulator was masking a "real" problem.
    But maybe there was a problem with the motor from day one (there is only about a week running on the furnace ... last winter).
    Here is want the factory said about the regulator pressure when I wrote them: "The LP pressure should have no effect on the Limit Switch opening. Of course the LP has influence on the flame but the gas valve in the furnace is a regulator that brings that pressure down to 10.0-10.5 inches so whether your LP pressure from your tank is at 11 inches or 14 inches, the gas valve should bring it down to an operating pressure (10.0-10.5) that feeds to the orifice."
    Manual says 11" min ... 14" max
    So I have touched the regulator ... but maybe I should?
    I am working on opening up ducting even more ... don't know if I can, not much room for more ducting in this are under the floor.
    Thanks .... Mike
  • Propane System Pressure 13"WC with furnace running??????
    Too High/Overfiring
  • How long does it take for the Hi Limit to trip? Have you checked the INTAKE from outside to make sure there is no restriction? A partial restriction would cause lack of some air to the burner, but usually this will cause a rich condition and black sooting. I would suspect a bad motor, not running at correct RPM's, but enough to make the sail switch close. With inadequate volume of air, the furnace burner casing will run hotter. The reason I suspect the motor is you stated that until now, the furnace ran correctly even before you attempted the ducting modifications. Doug
  • I did replace the switch ... but it could be a second bad one.
    I ordered two to I can change that out this morning.
    I am thinking of trying to open up the port next on the far side of the unit (second closest to the high heat switch).
    Maybe this will give enough air flow.
    maybe a floor register right off the unit and try moving the pipe that goes across to another port.
    I worked on it till 2 last night ... running out to look at it again ... trying to beat the snow and 9 deg temps (way tooooo cold here in VT) heading our way tomorrow.
    Thanks ... Mike
  • I added 2 extra registers to mine and solved the problem. Luckily my duct was rectangular metal right under the floor and I was able to just cut down into it.
  • I should have added that this is a 20 year old (1999) RV so I am a bit surprised to have this issue "pop up".
    No, I did not take any temperatures ... guess I should do that tomorrow.
    I guess that for the past 10 years (that is how long I have owned the RV ... even lived in it for three years full time) I could have missed it but I think this problem just started .. hard to tell since the furnace does not shut down, fan keep going ... re-starts after the high temp switch cools off.
    I though for sure that the longest duct had just failed after this many years and replacing it would do the trick.
    Now with the longest duct connected in hard smooth pipe ... two open 2" holes in the top plenum and a side port (never opened before) now open you would think this problem would have gone away.
    Maybe opening up the back port a bit (the one near the high temp switch ... the middle one is used now which is almost in line with the high temp switch) would let more air by it.
    Even with just the 2" bleed Tee open in the basement, it is actually much warmer down there now than upstairs in the cabin.
    Thanks .... Mike
  • size of ducting coming out. Heating can be large, Ac is the one you have to stay close to.
    Did you get a output temp with the duct and return
    did you get a return air temp with the duct and without when dump into basement. Just sound like you are not getting enough air thru the system duct. Which would be maybe a loose fan on the shaft.
