DamonOwner's avatar
DamonOwner
Sudden drop on MPG causes?
I have not used my 2008 Windsport 34B with a Ford V10 as much as I would like. However, I recently noticed on the last few trips out, my MPG has dropped significantly. Where I was averaging 6-7 MPG, I am now consistently getting about 3mpg (over a few trips of 200-800 mile ranges).
I know this is not much information to go on but any suggestions?
  • Temperature sensor or stuck thermostat most likely. Causes it to run rich.
  • You have something drastically wrong. Forget the tire pressure and easy stuff. Have a professional mechanic take a look at it. Probably a good tuneup will provide the mechanic with the facts you need to diagnose the real problem and fix it.
  • First thing i would check is the air filter.Second tire pressure.
