Tinstar
Jun 04, 2017Explorer
Only problem will be you can't dry the carpet below the surface although it will eventually dry. The smell is likely embedded deep inside and under the carpet. If it is soaked, the right odor control solution might fix the smell and you'll just have to hope for the best when it finally dries out. You might call some big cleaning supply company and explain what you are doing. They might have some good suggestions.
38,780 PostsLatest Activity: Nov 24, 2017
