T bone wrote:
Since the original post I have installed front and rear Sumos and a rear sway bar..also have a safe t steer..U am pleased with these additions.If I hit the lottery I will also add front sway bar. The rear one made a huge difference.only thing I am not 100% pleased with is the safe t steer. Can't seem to get it set just right.
One way to adjust it is to set up a cardboard piece on the dash so that you can drive down the road and put a mark when it is tracking straight.
Then you park the rig, lift the front wheels off the ground with the levelers and adjust the Safe-T-Steer to center the wheel on the mark that you made. This sure beats the trial and error method.
