Anybody running super singles on their class A??? For those of you unfamiliar with super singles they are a single WIDE tire/rim that replaces the duals on the rear axle(s) seen on some of the truc...
Mchero, you are the one confused. :S Cement and trash trucks often use super singles on the front that are wider than the one used on a semi. Heck, many of the big DPs are using 365/80/22.5 on the steer and tag axles... I would call that a super single as they will carry more than the 17,000 lbs/axle allowed on a semi with tandem axles.
