TDInewguy wrote:
One more thing...
I really hated trying to check the air in the inner dual... I wonder how many blowouts happened from a tire being low to begin with?
The super single is easy to check air in.
I second you on that! I came very close to disaster before I got my TPMS and the valve stem extenders in the inners leaked most of their air out. My coach has small wheel openings and it is very difficult to see or thump the inners so actually checking the pressure is crucial. In my opinion you may be better off with duals if you do have a tire go out but you are more likely to have a failure in the first place. I have had a pickup technically totalled by flapping rubber from a separation and heard horror tales on what that does to a class A. Being able to move the coach a little ways after separation may be a minor issue.
Thanks for the info on the smaller size singles, I will probably be buying tires in about 2 years and will have to check into them. Since I have steel rims and heavy wheel covers I expect to save even more weight plus making it easier to check tire pressure. I just ran some quick math and those tires are 2 1/2" larger in diameter than the tires that the coach came with. Maybe they will have some closer in diameter by the time that I am ready to buy.
Food for thought: Statistically private planes with twin engines are more likely to crash than single engine planes. This is probably a combination of there being so much more to go wrong and a pilot not responding correctly to a single failure. Even in boats twins are not much more reliable than singles because what takes out one often takes out the other. If someone can find some hard statistics on single vs dual tires that would be very interesting. I like facts a lot better than opinions, even my own.
