- IvylogExplorer IIIFrom my experience and many tests a stronger signal is faster than a weaker signal. The first two tests below are using my external/usb/yagi antenna showing five bars. The last two are 3-4 bars using my laptop's internal wifi/antenna over a two minute period. The results are 2-3 times faster with a five bar signal.
PS: The internal wifi is 200 mb while the external one is only 150 mb speed.
Sat Mar 22 2014 @ 4:59:49 pm Dallas, TX US US arrow 7.5 MB 3.55 Mbps 444 kB/s Bellsouthnet history 5O80YNE share history
Sat Mar 22 2014 @ 4:59:22 pm Dallas, TX US US arrow 7.5 MB 5.28 Mbps 660 kB/s Bellsouthnet history jUeLmC4 share history
Sat Mar 22 2014 @ 4:58:31 pm Dallas, TX US US arrow 7.5 MB 1.8 Mbps 224 kB/s Bellsouthnet history Z4g39SK share history
Sat Mar 22 2014 @ 4:57:40 pm Dallas, TX US US arrow 7.5 MB 2.44 Mbps 305 kB/s Bellsouthnet history L2vcshQ share history - tiredkidExplorer
joema62 wrote:
Has anyone used this particular antenna and if so what is your experience with it
may give u a better signal reading but if the park system is slow and or overloaded as most all are there is no advantage to such a device
I had a crane and it was a total waste of money - rvjamesExplorerWe use it and found it simple to setup and it seems to definetely help get a better signal. Doesn't help much with the RV park wifi being terrible but at least we can connect!
- RoyBExplorer IIIWe too have used the window suction cup Crane WIFI Antenna in the past for getting better signals at the campgrounds. Worked good for us... I use several CC CRANE items such as their CC RADIO PLUS and the AUDIO Transmitter unit.
We finally switched to secured Verizon MIFI plan and don't really mess with the camp ground WIFI anymore now... The MIFI plan allows up to five WIFI enabled devices on at the same time and works great all over the areas we go to here on the East Side of the US.
The big deal for us switching to the MIFI unit in addition to always having internet coverage is it creates a WIFI HOTSPOT and doesn't tie up one device to be used.
Roy Ken - gemertExplorerDon't tease "wecantwait!"! what is the cheaper more efficient model?
Thanks - We_Cant_WaitExplorerI had used a WiFi antenna by Crane in the past. It really helped in different campgrounds to provide a good signal. I had it mounted to my crank up TV antenna, I think this was the reason for the units demise due to vibration. I know others have used the unit to with great results. I just found a cheaper unit that does just as good.
38,776 PostsLatest Activity: May 15, 2026
