Dow12's avatar
Dow12
Supplemental Brake for Toad Recomendation
I have a 2017 Chevy Equinox that is getting the Blue Ox base plate and Avail tow bar installed today. I was planning on getting the SMI Stay-In-Play brake system installed at the same time. The installer called today and informed me that there is not enough room under the hood to do the install. Looks like I have to go with a portable brake system. Does anyone have any good recommendations on a portable brake system that is really easy to set up and reliable? I really don't have a clue on what to look for. I appreciate any help to help me understand the pros & cons as I begin my search.
  • If you have air brakes on the motorhome, you might look into the M&G Brake System. The M&G system is very small and goes between the vacuum booster and the master cylinder. You can find more info at http://www.m-gengineering.com/, there are several reviews here on IRV2 if you will do a search... and if you have an exhaust brake that activates your brake lights, I would seriously consider not doing the Stay and Play Duo, based on my experience. JH
  • I have the Brake Buddy Vantage Select and I'm very happy with it. I think the Ready brake has less setup time, but I have not used it.
  • Roadmaster invisibrake is similar to the SMI unit. The control box goes inside the vehicle.
  • Ditto on Ready Brake. The least amount of drama to hook up and especially when disconnecting; one cable does it all.
    There is nothing that takes power to operate, so no electronics, vacuum or pressure to fail.
    Look into it and you'll see it's the simplest and most straight forward solution.
    I tow my Suzuki Samurai with mine.
  • Its hard to believe they can fit the control box in. They ty wrapped mine to the battery clamp over top of battery in my crv.
    I love the stay and play.
