AZPops wrote:
. . . one of my primary concern (in my situation) is low voltage. I can't tell you how many times I woke up without power. When I check the P.I. EMS unit, it shows the low voltage error code.
When that happens, I disconnect, then run my generator.
Having to
manually start you gen could be problematic -- imagine losing power when an electric heater or other large draw device was running. This could run your batteries down to nothing.
That's why I had an auto-gen start installed. But I really want to avoid a loud gen starting up in the middle of the night.
So . . . for those low voltage situations, I bought an auto former with a 10% boost. So far no more running the generator.
