boogie_4wheel wrote:
Sounds like the torque converter is unlocking them locking back up. Most scanners and even free phone apps and using a bluetooth dongle will show torque converter clutch (TCC) status. Watch to see off the command is being lost to lock. If the command is not changing, then tapping the wiring at the trans and adding a light might be needed to prove a weak connection to the solenoid.
Unfortunately most mechanics will not pursue without a CEL as a starting point. And at $100+/hr it can get costly for a shop to try to track down an intermittent problem.
I had a TCC lockup solenoid fail on a 4L60E that resulted in weak and no lock conditions. It was easy to access requiring only dropping the pan. I don't know where it is on the 1000.
Just an additional thought about the converter lock up- Have you had any issues with the brakes?
Why I ask is applying the brakes cancels lock up. If a brake issue were causing brake pressure in the system it might cancel lock up. ???
Did Workhorse ever have brake hose issues?
Just a wild guess outside of the box.
