- HarvardExplorer
S1njin wrote:
Well I went to get my rig and ended up leaving it there another night. 3.5 caster? No thanks, at least 5 or bust !
Post by 2kGeorgieBoy
Re Wandering at highway speeds
Reply #36 on: March 14, 2018, 09:07:02 PM
START QUOTE:
Jeff..Although we have a 2000 Georgie Boy 31' Maverick "C" on a Ford E450 chassis, I can fully agree on the caster effects, at least for us. When we got the unit in Jan 2014, the dealer had us take into a truck shop for an alignment. It turned out OK....A trip to Moab shortly there after brought out the problems. I then started reading the threads and comments here about the caster settings....esp., from Harvard. I checked the data from the first alignment and found that it was set at about 3 1/2 degrees positive...about in the middle of Ford's recommended range. Shortly before a cross country trip to Maryland in fall of 2016, I returned to the shop where the first alignment was done. I talked to the service manager and he knew of the problems with the E450's and was happy to increase the caster as I asked. The alignment tech was also familiar with it and ended up with settings close to 5.5 degrees positive. WHAT A DIFFERENCE! The unit tracked straight down the road, passing semis no longer caused a white knuckle hold on the wheel, and overall it was just a lot more enjoyable. It did however increase steering effort a little but not anything to worry about. But, be sure that the shop you go to is willing to "think outside of the box". Our first alignment was "plain vanilla", right in the middle like it was always done. Second time out, they were very willing to increase settings beyond what normally would be done, and still stay with in Ford's guidelines (0-7 degrees, I believe). I realize that our E450 chassis is an entirely different animal than yours, but I was trying to add support to the caster increase thinking and how it helped us......if you go down that road.
END QUOTE: - S1njinExplorerWell I went to get my rig and ended up leaving it there another night. 3.5 caster? No thanks, at least 5 or bust !
- txneseExplorerI installed Bilstein 24-174534 5100 Series Steering Damper, Bilstein 33-187570 B6 Series HD Shock Absorber (Front), and Bilstein 33-176857 B6 Series HD Shock Absorber (Rear). Also changed out the Sway Bars with Helwig HEL-7008 (Front) and HEL-7180 (Rear). What a difference in ride quality and stability. No Regrets here. Took me about 2-3 hours total.
- SoloExplorer
S1njin wrote:
So what is the consensus best order of suspension improvements on a E450 motorhome?
My guess:
Proper tire pressure
Front end alignment
Rear Sway
Front Sway
Shocks
Steering Stabilizer
Rear Track Bar
Am i close?
On our formerly owned E450, I did all of those myself (and a few more) in a systematic procedure one-by-one and then tested to see the differences. So many variables here (road conditions, wind, towing or not, loads, driver preference, etc) that it is impossible to use my experiences as "this is how it should be done" but, our motorhomes were very similar in size so here goes for whatever it is worth in the order that I did them (doing it again, I would do the alignment in #2 spot):
1. Tire PSI-got accurate load data from a certified scale and used the Michelin data to adjust. Result: smoother ride, less lane drifting.
2. Shocks-Replaced 2 year old factory shocks with Bilstein. Result: Less "jarring" on expansion joints, less rocking side-to-side, nice improvement.
3. Roadmaster Reflex Steering Stabalizer-Result, centering on crowned road surfaces was appreciated.
4. Alignment: I had way too much + camber, not enough + toe and not nearly enough + caster. Result: Much less wandering at highway speed, drastically improved tire wear (from decreasing + camber).
5. Front and rear sway bars. Replaced the factory Ford front and rear with Helwigs. Result: Reduced side-to-side sway and minimized being pushed around-good improvement.
6. Rear panhard bar (track bar). Result: No noticeable difference.
7. Rear air bags (the original motorhome had none). Result-less "pounding" on expansion joints from the rear, smoothed the ride, nice improvement.
In the end, a predictable chassis to drive in most situations. Wind was still our enemy and living in the Great Plains, we know wind.
Yes, you are close. Good luck with your challenge. - j-dExplorer IIRon IS an engineer with the disciplined mindset that comes with it.
Me? Experience, much gained the hard way... mistake. So, put BORG custom valves from CW or duallyvalve.com so you can check quickly and often.
You will find the tires have not lost air like they did with OEM or rubber valves, extensions and such.
If pressure is down, something is wrong. Start looking for that roofing nail, drywall screw etc.
I can check six tires and two airbags in a minute or two. That's ALL not Each. And with any gauge.
Airing up is 3 months or so.
Don't forget the SPARE. - S1njinExplorerI've got 2 of those digital ones you posted about. They are within .5 psi of each other, so I've been using those as my accurate gauges. The gauge I use w/ the double chuck tire filler is off by 4psi on the stingy side. So I know I need to add 4 to whatever that gauge tells me.
- ron_dittmerExplorer IIIYes, 5 psi makes a difference. That is why having an accurate tire gauge is critical. Click Here to read a post I wrote on my experience evalating all my tire gauges. What I thought was my best tire gauge, was my worst, off by whopping 9 psi.
- j-dExplorer II
S1njin wrote:
..It’s amazing what 5 pounds in the front will diií
Thank you for saying that!
Proper pressure is always a factor.
Ford E-Series with RV on its back, it is essential.
Take pressure from Michelin Chart based on actual truck scale weight. Loaded for camping, people and all.
Add a few PSI..3+4..if tires are warm.
Don't play Outguess The Engineer.
Cash in on the Hard Earned Experience of others. - HarvardExplorerNot just +5 Caster, take all you can get.
- S1njinExplorerSo I put about 250 miles on her this weekend. The ride out with 75 in the fronts wasn’t bad. The ride back with 70 was a whole lot better. It’s amazing what 5 pounds in the front will do. I didn’t weigh myself yet, but my Greyhawk was 5 feet longer and 800 pounds heavier from the factory and I could have put 70s in the fronts after weighing on the way to Disney for 10 days. I didn’t see myself at risk in my more modestly proportioned camper.
So tomorrow is alignment day at the truck shop. I’ll ask for plus 5 caster when I drop it off.
