DrewE
Oct 04, 2019Explorer III
Definitely check the tie rod ends and ball joints; my first guess would be the tie rod ends. If you have a steering damper (I think that may just be on the E450 from the factory), see if it is worn also--or if it looks worn or leaky, just replace it as they are not all that expensive or hard to replace. When I replaced mine I discovered that it seemed to have an air bubble in it, presumably from having some of the fluid leak out over time, which caused it to be elastic for small movements rather than damping them out...and replacing it had a noticeable positive impact on the steering feel.
38,766 PostsLatest Activity: Jan 10, 2026
