youracman
Oct 04, 2019Explorer
Jayco-noslide wrote:
I think it is better and probably needed done but I don't think it can be even better until the play is taken out of the wheel and no one has addressed that. Have already spent around 5K and really don't want to spend another $1000 or more. Comments?
I sure agree re the steering wheel play. My 12-yr-old rig has several after-mkt "handling upgrades" much like yours (exceptions: yours has a track bar; mine doesn't and I have adjustable bushings that got me 5 degrees positive caster dunno if you have that mod.) Each mod gave me noticeable improvement but there is still steering wheel play (and the Denver medium duty Ford truck dealer told me that I did not have appreciable wear in any of the steering components when they aligned it....so tie rod ends etc are not the culprit.)
So my rig goes reasonably nice and straight down the road when there is smooth pavement with not a lot of crown, very little wind and no 18 wheelers around (my 220 inch wheelbase is a plus)...... so I (don't, but I can) drive it just fine with only my index finger wrapped around the steering wheel BUT when a little correction is needed, I have to move the steering wheel about 2 or 3 inches before anything much really happens. I believe that is what you are calling "steering wheel play"..... and I am thinking it is really common in Class C's with the medium duty truck chassis; e.g. Ford E450. FINALLY....my comment: I have been told that this is inherent in "recirculating ball" steering boxes and it is almost non-existent with rack and pinion designs. The recirculating ball boxes are said to be stronger than other designs (hence used on med duty trucks and off-road vehicles a lot.) "Redhead" in WA state "blueprints" all kinds of steering boxes by hand-fitting different components into them so that the slack is nearly eliminated. I emailed them to see if they had "off the shelf" boxes available for an E450 and they do not.....so I would have to send mine to them or drive my rig to their plant and they would complete the work in one day (IIRC the cost was about $350 or so.....for the box, that is.) Neither approach will work for me so I will put up with the play.
Good times and safe travels to ya.
38,766 PostsLatest Activity: Jan 10, 2026
