10forty2
Jun 12, 2017Explorer
When I first got my coach, I noticed an excessive amount of body sway....read about CHF, crawled under to start the job and noted the bushings were completely deteriorated on front and rear. Ordered the poly bushings, installed them and the coach no longer sways like it did. Still have a bad leaf spring that needs replacing, but the sway bar is able to do its job now.
Order the poly bushings and make sure you put the supplied grease inside them before you install....otherwise you'll get an annoying creak everytime the bar moves.
