wolfe10
Oct 16, 2013Explorer
Sorry, there is no way to remove debris from the FRONT of the CAC (where the vast majority is accumulated) by flushing backwards/from the rear. Theory is correct, reality is not.
Remember how the cooling package is installed. You have two layers with the CAC in front of the radiator. Yes, you need to clean from the back (cleans the radiator), but were you to use enough PSI to go through the radiator, air space and the CAC with enough force to knock stuff of the front of the CAC, you would likely bend the fins on the radiator from excessive pressure.
But, if this is your approach, clean it from the back and then use a strong flashlight to check the perimeter of front of the CAC.
38,766 PostsLatest Activity: Jan 10, 2026
