FarmerBob wrote:
I have a 2006 National 29'. On the left when you go in the door there is a switch box with compartment light switch, step, porch, battery disconnect buttons. The battery disconnect and step switch do not work. I wanted to disconnect the house batteries for the winter but I cannot do that with the door closed, so that means the steps will be stuck in the out position. Anyone know how I can fix this? Not sure how to post a picture of this switch box.
Thanks, Bob
Possible to just get to the Battery and disconnect the ground - usually the battery is located outside.
(Or is in inside under the steps?)
Just a thought,
