supercubExplorerJun 22, 2014Switching from inverter to genertorDo you turn everything off when switching from the generor to invertor and vice versa? or is it ok to leave everything on? Also, what happens if you're running on the inverter and turn the generato...Show More
2oldmanExplorer IIJun 22, 2014A lot of this depends on how your transfer switch (xs) is wired. Generally, you don't want heavy loads running when XS switches.
Related ContentInverter Bad?Switching toiletsAutimatic Transfer Switch?Inverter installC class genertor
