RVUSA
Nov 24, 2013Explorer
Gjac wrote:
I was hoping that by going back to dino oil in the gen set it would stop or slow down the leak.
If the leak is because of a bad rubber seal like a crankshaft seal, then some "lucas engine oil stop leak" will fix it, but you will have to add it every time you change oil in the genny. If it's leaking past a paper gasket then you will have to fix the gasket. If it's leaking from a bad sensor (oil pressure etc) you will have to replace the sensor. Or live with the leak.
But you cant fix a leak by changing the viscosity of an oil. Even 90 wt. racing oil will leak past a poor seal.
Do you know where it's leaking from?
38,769 PostsLatest Activity: Mar 29, 2026
