Jarlaxle wrote:
Oil is oil. If you like wasting money, go for synthetic. Otherwise...use whatever 15W-40 you can get the cheapest.
If that's what you believe then go with it. Personally I think you're wrong but that's okay. Syn doesn't start breaking down until higher temps than dino oil. Syn reduces friction more than dino oil does. Different oils have different additives that do make them different. I can provide you with a list of oils, wear tested by an engineer, that shows how many PSI all the leading brands will survive before 2 pieces of steel start to wear or scuff. There are huge differences but if you want the cheapest then by all means buy the cheapest.
15-40? Is that what your engine manufacturer recommends? That's pretty heavy oil.
