WILDEBILL308 wrote:
RVUSA wrote:
wa8yxm wrote:
Jarlaxle wrote:
Oil is oil. If you like wasting money, go for synthetic. Otherwise...use whatever 15W-40 you can get the cheapest.
You are right and wrong at the same time. Yes, Oil is Oil, however some Oil is highly contaminated, some is highly pruified, some is highly refined some is not.. This is why there are different brands and prices, Oh, and some is recycled and some is not.
Amzoil is a LUBRICANT, it is not oil, it is synthetic. So it is a different critter entirely,, Takes the place of Oil though, Mixes well with Oil though, but it is not oil since it never came out of a hole in the ground.
pssst...
amsoil uses a base oil. No oil regular or synthetic is created in test tube. They ALL use oil as their base. It is oil not a lubricant.
Perhaps you are confused because some company’s use Group III - this is a highly refined mineral oil made through a process called hydrocracking. In North America this group is considered synthetic oil, for marketing purposes. You might want to do a little reading on the Fischer–Tropsch process.
Bill
They ALL use oil as the base, Amsoil included. Refined or cracked and then put back together in any blend you want, it's STILL oil.
There is no confusion.
