STEVEP220
Jul 03, 2015Explorer
Tag Axel
I own a 38" DP with 1 slide. I am looking at purchasing a 2012/2013DP with 4 slides and maybe a tag axel. I am looking at a Tiffin Phaeton/Bus 42/43 ft.. My questions are (1) is a tag axel worth the e...
Skid Row Joe wrote:Kayteg1 wrote:Not entirely accurate.
If you need tag axle for driving straight, you start from wrong point.
Tag axles are for extra weight carrying and on good coaches they are liftable.
I had my vintage Prevost park in spot with sharp turn required, so lifted tag for better turning.
200 miles later I start thinking "did I lower the tag down?"
I did not and could not tell the difference in driving but fact is that it was slower driving in weekend traffic.
The tires on bus conversion operate at 60-70% of weight carrying capacity, so dropping another 30% is not posing any danger.
Tag axles are for braking purposes, first and foremost. Everything else is gravy, or non-essential. The fact that their GVW rises significantly, is icing on the cake. The beauty of the tag axle comes into play when in a sudden cross-wind, as well as the fact that a tag axle coach RIDES significantly better/smoother.
