I have been watching You Tube on Motorhome reviews and some thing I would like you guys who have tags answer or give your opinion on them. One guy says that the steerable tag axle is not worth it an...
I would keep it simple and use a fixed position, non-steering tag axle, if the tandem is standard spaced. If it is a spread axle tandem, then a lifting tag axle may be helpful. I've not seen any spread axle tandems on motorhomes though. Seen plenty spread axles on flatbed semi trailers.
