Executive45
Oct 13, 2015Explorer III
Tag Axle Question
We traveled US95 yesterday through Nevada. (Between Carson City and Las Vegas) If you've been on that road you'll know there's nothing but desert and abandoned towns, or at least one's that should be. Anyway while cruising along I got to thinking about the tires. With that in mind I wondered if I had a flat out there on the tag, could I simply remove that tire and drive on into Vegas? Or if one of the other tires went, could I use one of the tags as a spare? What, if anything would be the result? I understand the tag is there for weight distribution. Reasoning says it would be possible unless you're close to maximum weight. I also thing both tag tires would have to be removed but maybe not. Any "experts" out here that can give me a definitive answer? Thanks....Dennis
