Daveinet wrote:
Just to be clear, there is a difference between a sway bar and a panhard/track bar. Do you actually have a panhard bar?
Coming from memory here since it is pouring outside, but I remember looking under and seeing a bar mounted from the curbside axle coming across to the street side frame. It is maybe 1.5" in diameter plus/minus. I assumed that to be a sway bar and I may also have the panhard bar (whatever that is) as well. Don't know what to look for actually.
Ps. Wildman, I tried several different tire pressures and none of them made any difference.
Pss. I am familiar with tire squirm on new tires rgatijnet1. That is what the trucks I mention in the first post were experiencing. These Toyo's probably have 5K on them so not likely (but never sure) the problem. Again, I have had Toyo's before, but then they could have changed the compounding. If other who have them pipe up about recent Toyo problems, then that is new data I can work with and what make forums like this so valuable.
