Bordercollie
Jul 20, 2016Explorer
If it's just corrosion and it has not eaten through the sockets, I'd disconnect the starting battery and try to grind corrosion away with a Dremel tool and drum sander and maybe a grinding stone used gently to clean brass contacts. Reconnect the battery and install fresh bulbs. Might need to squeeze socket a little to make good contact with the bulb bases.Worth a try!!
38,783 PostsLatest Activity: Sep 10, 2026
