twmonroe wrote:
Hi ... looking for opinions from experienced Class C users on this one. My old Class C had a tag axle and did not sway a bit. Traded it for a 2006 32 ft Class A, which wandered all over the place until I put a hefty sway bar on the rear end.
I'm looking again at Class C's since they fit my needs for camping with grandchildren better, but I'm concerned about that long rear end sticking out past the axle, and worried that the tail is gonna wag the dog badly.
On a new 31 foot Minnie Winnie, will I get thrown around by wind, passing trucks, etc?
Tom
Test drive it thoroughly (as in, in the wind, on the interstate, around town in heavy traffic and if the dealer balks, run - do not walk to the nearest exit as they obviously are hiding a defective unit). If it does not drive well don't buy it! :S
The nonsense of folks buying new motorhomes and then having to spend thousands of dollars to make them "drivable" is absurd! Keep in mind that on any test drive the coach will be far lighter than it would be in a real world situation. Any coach you test drive should have the proper tire pressures and a decent alignment before you set foot in it. While these issues can be addressed why would you buy from any dealer who cannot properly set up a safe functional coach??? :h
A new motorhome should need NOTHING, right off of the dealers lot to make it drive and handle well (safely). If yours doesn't you bought the wrong one. :R
As always.... opinions and YMMV.
:C
