happy-2ExplorerApr 07, 2016tank drainwhen is the best position to drain your tanks?when the rv is on the ground,or when it is on site and level. do the tanks drain slop to the rear.???
2oldmanExplorer IIApr 07, 2016I can say with much confidence that the mfr designed them to drain when level.
Related ContentGrey water tank won't drain completelyHouse battery drainBlack tank not draining!Fresh water tank drain.Draining hot water tank
