shirleyj62 wrote:
Dick_B wrote:
Isn't this a duplicate of a few days ago?
If not, search this Forum for `tankless' and read on.
This is not a duplicate. Since our dealer will not discuss removing the tankless heater, I'm trying to figure out if this is even an option for us regarding costs and hassle. I'm hoping that those persons who had it removed, could give us a ballpark figure of what it costs them.
Thanks
Shirley
What do you mean he will not discuss it?? If you mean you want HIM to replace at NO CHARGE, then I understand why he won't discuss it. You can replace with a conventional Water Heater, but that means spending about $1000. Tankless Water Heaters need continuous operation and doing "navy" type showers makes them run hot and cold. Make sure ALL the air is out of your water system. Check the outside shower and flush a few gallons of water thru it to make sure the air is out of its lines. ANY small air pocket anywhere in the fresh water system will cause Tankless to run fickle. Doug
