shirleyj62's avatar
shirleyj62
Tankless water heater
We are new owners of a Jayco Precept MH. We are currently in our second week of using it. One thing we are having a difficult time with is the tankless water heater.
Not only are we suffering from the scorching hot/freezing cold syndrome of the water, but we are also concerned about the amount of water usage. Most of our camping is done at state parks, COE, or county parks. The majority of these are not full hookups. In the past we took "navy" showers so we could limit the amount of gray water in our tank. The tankless water does not seem to like the off/on of the water. In addition prior camping units ran on either propane or electric. We always used the electric conserving our propane.
We have tried talking to our dealer about switching out the tankless water heater for the conventional water heater. So far he has been reluctant to even discuss it.
Has anyone else switched out their water heater? If so, may I ask how expensive it is to do so?
Any other advice/suggestions you may have would be welcome.
Thank you,
Shirley
  • I would first work with the heater manufacture. Tank less heaters work with water flow. Not enough flow and they won't come on. Might be the thermostat is set too high and your attempts to get of comfortable water temp may not be enough to trigger the system.
    Replacing the tank less is certainly an option considering both a tank or tank less have pretty much the same foot print but you'll looking at a bill of over a $1000 to make the change (cost of the new heater, new propane lines and associated labor at around $100 hour). Plus the original coach builder warranty probably won't cover the new heater which might complicate matters.
  • Ivylog's avatar
    Ivylog
    Explorer III
    MM, comparing a $100K small Class A with 60 gallons of water and a tankless heater to your $1.8 million DP with 150 gallons of water and a AquaHot were I doubt you shut the water off during a shower???????
    OP, follow Doug's advice. It might be possible to move it closer to the shower for less $$$ than replacing it.
  • shirleyj62 wrote:
    Dick_B wrote:
    Isn't this a duplicate of a few days ago?
    If not, search this Forum for `tankless' and read on.
    This is not a duplicate. Since our dealer will not discuss removing the tankless heater, I'm trying to figure out if this is even an option for us regarding costs and hassle. I'm hoping that those persons who had it removed, could give us a ballpark figure of what it costs them.
    Thanks
    Shirley
    What do you mean he will not discuss it?? If you mean you want HIM to replace at NO CHARGE, then I understand why he won't discuss it. You can replace with a conventional Water Heater, but that means spending about $1000. Tankless Water Heaters need continuous operation and doing "navy" type showers makes them run hot and cold. Make sure ALL the air is out of your water system. Check the outside shower and flush a few gallons of water thru it to make sure the air is out of its lines. ANY small air pocket anywhere in the fresh water system will cause Tankless to run fickle. Doug
  • Mr.Mark wrote:
    Shirley, I guess my question is.... are you sure that the tankless is working properly?
    We have a hot water tank AND a tankless for the shower. I turn off the shower to lather up and the water is hot no matter how long I keep it off and then restart.
    MM.
    Unless I'm mistaken, I'd imagine your tankless is diesel powered, not propane. Am I right?
  • If your tankless is Precision Temp call the service number 800-934-9690 and talk it through with Gary. He can explain how to resolve most of your problems. When working correctly it does not use a lot of propane as it only heats when you are drawing water. We have a one handle shower and just turn it off and back on when taking Navy showers. It works much better then the dribble closure which does not work at all with the Precision Temp. If you have the Girard my understanding is be prepared to eat the expense of changing out. I cannot imagine a dealer making the change for either of them at their expense, why should they, you bought a feature :)
  • That would be my thought as well. It simply may need an adjustment.
  • Shirley, I guess my question is.... are you sure that the tankless is working properly?
    MM.
    Thanks
    Shirley
  • Isn't this a duplicate of a few days ago?
