femailyetti
Dec 24, 2017Explorer
taping roof
hHow clean is clean? I have scraped it with a a scraper, wire brushed the residue left sticking to the joint. There is still a thin layer of sticky black residue left from the wire brushing on parts. safe to put the tape back on???? I don't want to have to do this again for a while and I don't want it to leak.
If you have stains that are still difficult to remove, like tree sap, try mineral spirits, but with a BIG CAUTION: Do NOT use mineral spirits unless you carefully follow these directions. Mineral spirits is a petroleum distillate, and a rubber roof can react with swelling, deterioration and discoloring.
DIRECTIONS: NEVER pour the mineral spirits DIRECTLY ONTO THE ROOF! Always pour a SMALL amount on a soft cloth (less is best) and then use the cloth to scrub out the stain, using only as much as needed and wiping it up with another cloth when the stain is gone.
See picture in my restoration post for documentation on what is left at this point on the joint that needs taped.
