rgatijnet1 wrote:
I've had the Taylor EXTREME wires for 55,000 miles so far and they are still doing well. This set comes with the extra heat shields around each plug wire.
 Some coaches did not have the front end designed with enough openings to provide proper air flow to the engine compartment. For those coaches, WH sold an accessory kit to provide more air flow over the rear of the engine. I'm not sure if any of these kits are still available but you may check with "workhorseparts.com."
Taylor Extreme
same thing I put on my PA when I had it.Never had another problem.
