dougrainer wrote:
goufgators wrote:
sharker6 wrote:
Do you have an antenna booster button? Is your input selected correctly on setup, and do you have antenna selected and not cable?
No antenna booster button. Input was correctly used on set up. Had Antenna selected.
This is your problem. You HAVE an Antenna Booster button.
You just have to find it. Follow the TV coax to where it is connected. Doug
X2
Mine is located INSIDE one of the cabinets above the couch!
Take a flashlight with you so you can see either a button or switch to turn on the booster. THEN a small red light should appear when it is turned on.
Booster not on = no TV channels.
