dougrainer wrote:
goufgators wrote:
sharker6 wrote:
Do you have an antenna booster button? Is your input selected correctly on setup, and do you have antenna selected and not cable?
No antenna booster button. Input was correctly used on set up. Had Antenna selected.
This is your problem. You HAVE an Antenna Booster button. You just have to find it. Follow the TV coax to where it is connected. Doug
May HAVE found it! In a cabinet above the sofa is a coax plug in and beside it a very small light that was shining 'green'. No stations found with the light showing green or with the light out. Beginning to think per another response that I'm just too far from any over air stations. Our previous MH had the type antenna that could be raised and we had no problem pulling in over air stations with that antenna. This MH has a very small antenna that sits almost at top of MH. Seems that all that comes with a brand new MH is not always better than on older ones!!
