- rgatijnet1Explorer IIIIt also depends on how you want to listen to the audio on the TV. If you feed it through another amplifier, no problem. If not, and you plan to build it in to a cabinet, you will probably need a TV with the speakers in the front.
- OasisbobExplorerOnly special consideration that is different from a home TV is size. If you book dock a larger screen equals more power required. I would personally go with an extended warranty due to road vibration and temp changes.
- rk911Explorerain't no such thing as a motorhome TV. any old TV can be used/installed in. MH.
- Johno02ExplorerWalmart.
38,708 PostsLatest Activity: Mar 06, 2025
