real4u2c's avatar
real4u2c
Television upgrades
Can one or all of you point me in the right direction to go with getting a TV upgrade for my mh.
  • It also depends on how you want to listen to the audio on the TV. If you feed it through another amplifier, no problem. If not, and you plan to build it in to a cabinet, you will probably need a TV with the speakers in the front.
  • Only special consideration that is different from a home TV is size. If you book dock a larger screen equals more power required. I would personally go with an extended warranty due to road vibration and temp changes.
  • ain't no such thing as a motorhome TV. any old TV can be used/installed in. MH.
