Tinstar's avatar
Tinstar
Tell me if I'm doing this right with my multimeter (UPDATE)
I'm trying to measure the parasitic drain on my battery. I know how to do it with a multimeter but I'm not positive about the digital reading after the measurement.
I've got my meter set to DC current with the leads on COM and the 10A MAX ports. I take the reading between the negative battery post and the negative battery cable. The battery is at 13.4 volts (fully charged). Everything is turned off, no lights, no radio, key off, etc. etc. etc. Everything is as it should be to check the current draw. I know there should not be any more than 1/2 of an amp draw reading (unless there's something wrong). That half amp is the parasitic drain and keeps the radio setting, computer/s, etc. active.
Now for my question about the readout: My reading is 0.24 on the 10 amp scale OR 2.5 on the 200m scale. As I understand it, I have 1/4 amp draw. Am I correct in my assumption? If so, all is good and there is no out of the ordinary parasitic drain.
  • .24 on the 10 amps scale is about a 1/4 amp. I don't think the 200 ma scale will work on most meters when using the 10A jack. I would ignore that number.
