dougrainer
Aug 25, 2018Nomad
zigzagrv wrote:
If I have the A?C on and want to make it a little less cold, turning the knob just a 1/8th turn causes warm to hot aire come out in about a minute or so.
Just looked under the hood and found what I believe to be the vent control, which blocks or allows outside air to come into the cabin. Where can I expect to find the blend door?
That outside door you found is to allow fresh air in to the Evap and heater core. When you go to MAX AC, that door closes and it recirculates air from the cab interior. THERE IS NO BLEND DOOR. As I stated, Gas model Motorhomes do not have the fancier blend door systems Auto's have. I have and still am working on Motorhome Dash AC systems for the past 38 years. Doug
