Bordercollie wrote:
From what I have seen, car batteries for EV's consist of lots of little cylindrical batteries that add up in weight. As an RC modeler I use "Lipo" batteries that are quite expensive and require careful, slow, balanced charging. They require discharging to storage level 3.8 volts per cell. If we crash a model and damage a battery pack it may become unsafe to use or store. It may be that EP car batteries use safer, more robust, chemistries and the above may be or become irrelevant. It seems that miles between recharges is still a concern to EV users.
A concern sure. A problem? Depends what car you bought and expect it to do. An 800 kilometer road trip in our EV takes about the same as it did in our Grand Cherokee. We haven’t gone much further than that so can’t say. For us that’s all we need it to do. Different folks have different needs.- BordercollieExplorerFrom what I have seen, car batteries for EV's consist of lots of little cylindrical batteries that add up in weight. As an RC modeler I use "Lipo" batteries that are quite expensive and require careful, slow, balanced charging. They require discharging to storage level 3.8 volts per cell. If we crash a model and damage a battery pack it may become unsafe to use or store. It may be that EP car batteries use safer, more robust, chemistries and the above may be or become irrelevant. It seems that miles between recharges is still a concern to EV users.
- GjacExplorer IIIFrom my experience in aircraft design when ever a new piece of equipment is added to the existing airframe it adds a lot of weight because the surrounding airframe has to be beefed up to support the added item. However when the paper is blank the required item like an antenna for example can be integrated in the the structure for a lot less weight. So an antenna can be part of the structure, be an antenna and a grab handle all at the same time. Having said all that I think the only way that an electric RV can save weight is to integrate the batteries and other electrical stuff say into the initial design of the box beam frame for example or making the RV shell where the outside layer of fiber glass is replaced with a bonded on solar panel film thus reducing the over all weight. I don't know enough about solar to understand if the panels are getting more efficient as a function of time like Moore's Law in electronics or not. I know cost has come down over time has the efficiency improved also? If so can solar add much charging to the batteries to make it worth while in 5 years? 10 years? any years?
Rick Jay wrote:
ALL my home LED and RV LED lamps are still working. Some more than a decade.time2roll wrote:
Battery should last 20+ years and currently prices are still dropping.
I know this is an apples to oranges comparison, but if those "20+ years" of expected battery life are anything like the "22+ years" some of my LED replacement light bulbs promised me on the package, we're going to be in trouble. LOL
I've changed probably 20-25% of the LED bulbs I've installed since I converted our sticks & bricks house to LEDs about 4-5 years ago. And they didn't get bounced around on New England's famous pot-hole filled roads for 6 months of the year!
Just saying! :)
~Rick
Even if you have a few fail you have collectively saved enough electricity to pay for replacements. LED bulbs will definitely pay for themselves in direct costs. An EV maybe not so much.
You did not go back to incandescent did you?- pianotunaNomad III
Just saying! :)
~Rick
Rick you may have an over voltage problem at your home.
I've changed just one led out of 34 bulbs in a five year time span. That one started to flicker. My bulbs came from a dollar store. - Rick_JayExplorer II
Just saying! :)
~Rick Bordercollie wrote:
Have you driven an EV? They actually 'feel' lighter and handle better due to the lower center of gravity. Battery should last 20+ years and currently prices are still dropping.
If weight and cost of batteries, plus power consumption to quick charge vehicles can be greatly reduced, electric power may become a viable alternative. I shudder to think of handling curvy mountain roads in an extremely heavy motorhome and paying for a new set of batteries when needed.- BordercollieExplorerIf weight and cost of batteries, plus power consumption to quick charge vehicles can be greatly reduced, electric power may become a viable alternative. I shudder to think of handling curvy mountain roads in an extremely heavy motorhome and paying for a new set of batteries when needed.
Bordercollie wrote:
Somebody make the electro-power fanatics aware that motorhomes only average some 5000 miles per year and that "replacing" gas and diesel powered motorhomes with much more expensive, and much heavier, electric powered ones would not greatly improve the environment.
Yah. I don’t think manufacturers will build EVRV’s for environmental reasons. It will end up being for performance reasons when the technology allows.- BordercollieExplorerSomebody make the electro-power fanatics aware that motorhomes only average some 5000 miles per year and that "replacing" gas and diesel powered motorhomes with much more expensive, and much heavier, electric powered ones would not greatly improve the environment.
38,768 PostsLatest Activity: Dec 18, 2017
