Kevbarlas1
Feb 21, 2011Explorer
February update
I'm afraid this update is pretty much the same as the last, stripping paint.....joy. Finally the chassis and floorpan is pretty much done. There is still a few remaining patches to clean up but im going to do them when i start welding the underneath. No point cleaning rust that im going to be cutting out.
This was with the sandblaster.
You can see that because the blaster isn't under a really high pressure and the grit has been used a few times that it leaves the pits with rust in them, granted it is just surface rust.
A bit more of a close up of that panel. The panel is still strong, its just heavily pitted and as its the underside and to keep originality im going to keep it like that. I'll use a good quality rust-converter (fe-123 http://www.rust.co.uk/rust-converters.cfm ) on the panel first then use that same companys epoxy-mastic chassis paint. The company always seem to get really good reviews in magazines.
When i had finished cleaning underneath i rolled the van back the right way round and stared at it for a while, trying to build some enthusiasm back to get on with the laborious task of blasting. After 10 mins of doing that i put the kettle on and rolled a smoke and sat back down again. I suddenly remembered that when i was at my mates garage looking at his Thames he was telling me about these poly-abrasive discs he had which were meant to strip the paint without damaging the metal-work at all. I looked in the catalogue and they are £7 for a 115mm disc so i thought i may aswell try it, so i bought 2. Heres what a part worn one looks like.
I decided to try it on a small area just underneath where the passenger seat would be. It has a flat area , a curve and some folds so i thought that would be a good enough test for what it would encounter on the outside.
Wow!, i was impressed. I would like to shake the mans hand that came up with these. Its like the perfect balance of enough abrasive to remove the paint and not harm the metal. It leaves the panel lightly scored but probably to the same effect of about 120 grit wet and dry. Best of all, that panel took maybe 4-6 mins to do completely. Compared to about twenty minutes of the blaster probably. Plus i don't have to then sieve the grit etc.. Well worth money. The first bit of the outside i done was a small area just behind the passenger door.
I then moved onto the rear
When the discs are new they are about half an inch thick. I found out that if i use them new on the swage lines around the windows i could get the disc right in and clean the detail bits up first then when they get part-worn i would move on to the flat surface areas.
So, ive now came up with another new plan regarding stripping the paint. The idea now is to do as much as i can with these poly-abrasive discs then use the blaster to get into the hard to reach areas like the door openings, under the dash, hard corners etc.. for some reason, I was a bit annoyed with myself that i never stuck to blasting the whole entire van, like i felt i was taking the easy route out and being lazy. Im trying to see it as more of a positive approach, I guess its all a learning curve. At first i was adamant that i would sandblast the whole van but these discs cut the time dramatically, id say it takes atleast a fifth or a quarter of the time it would take to sandblast these areas. plus the compressor doesn't need to be on so its much more quieter.
The next weekend i went to my mates house again and he gave me a fuel/vacuum pump for the Consul. He also gave me a bigger 7 inch (180mm) polyabrasive disc as he said he wouldn't be needing it, bonus!. Only problem is i don't have a 7 inch grinder so i done what any stupid person with no regard for there safety would do. I put it on my 4 and a half inch grinder and, with welding gauntlets on, I held it very very very carefully. It acted like a huge gyroscope but done the job.
I finished off the panel i started the week before. Once i get the metal bare i give it a quick rub down with a scotchbrite pad to remove the dust and give it a duller finish.
I then moved onto the front. You can see the difference here between the sandblast finish and the poly-abrasive disc.
The front took maybe 35-40 mins to get to that stage, Its great to actually go to the garage and see some instant results for a change. After a sandwich, coffee and some cookies i started on the side.
The way it leaves the panels in a sort of brush effect can make the light hitting it give the impression of dents and dings but this side panel is amazingly straight apart from one little dent on the lower half.
This side is also the worst around the swage line for rust, heres a close up from the outside.
And the same area inside
It doesn't look too bad outside but the inside is all completely rotten. Heres a crappy mspaint cross section to show you how they look.
By the afternoon i had stripped pretty much every outside panel on the van.
I even had enough time to make a start on the inside.
Im so much happier to see progress happening. I think next weekend i could get the bigger panels on the inside done and then il be onto blasting the hard to reach areas. Hopefully within the next 3-4 weeks i could have it completely stripped of paint ready to get welding.
I have a question now though, once its all stripped i need to protect it from surface rust as im working on it. Whats the done deal here? I was thinking that i would go over the van with a sander to make sure any surface rust that may have formed since i started would be completely gone. Then spray a coat of etch primer to protect the body. Does anyone else have any suggestions?
On a completely different note, The engine idea has changed. As i said before i was going with the Ford Cologne 2.8 V6 but i think ive found something better. Ive been measuring the engine bay area and i think with some slight modification i could shoehorn a 1UZ-FE in there, in other words, a 4 litre, 24 valve V8 from a Lexus LS400. Ive seen complete cars for £450 so i can scavenge the V8, radiator, auto-box, complete wiring loom etc.. for just about the same price id pay for the V6.
250 BHP and 260 ft·lbf of torque, yes please!
38,780 PostsLatest Activity: Aug 05, 2026
