Kevbarlas1
May 07, 2011Explorer
A little re-cap,
I started by cutting the rusty section out and making a cardboard template.
I then had a think about how to make it. As you can see it has a slight curve in it the whole length and theres also a curved lip. I thought the best way would be to make the bottom section out of 3 folds then cut the upper 3 section seperatly and weld it all together. Like this.
As I was welding I think I may have done it too quick as it did start to distort slightly. I managed to tap it near enough back into shape. The only thing is the part that holds the gutter in place is still a bit warped. I don't know if I'm trying to make it too perfect or if it is actually crap. The part that will be seen once its all back together is ok and so no one would know how it looks. This is how it looks just now.
I wasnt too happy with it but after showing my dad and a few other sheet metal workers they say its quite good. I tweaked it a little from when i took these photos and i feel happier about it aswell. I do self doubt myself a lot which can be a bad thing at times. It sort of hit me when one of my friends who does this stuff for a living said that people spend years and years with the proper tools to achieve a perfect flawless repair part. I dont have that much time. I havent fitted it yet as i need to fix up the A post first, its rusting quite badly all the way down from the inside but the way the panels are joined im having to take my time and think about the best way to go around fixing it.
To be honest. The first part of the van i done i wasnt happy with so i never posted it but seeing as i think i'll re-do it i'll show it here. I really started on the metalwork one night when i was bored and went to the garage instead of home. It was a little bit around the windscreen that had rusted quite badly.
I cut it out and made up a patch, it has a slight slight curve to the panel which i managed to get.
Then i tacked it in and welded it up. When i dressed it all off i realised i never really lined it up very well on the left. You can see its about 1/2 - 1 mm lower, thats why i never wanted to show it at first but hey, we all make mistakes and its all part of learning.
Anyways, back to the better stuff.
I went and bought some really good rust convertor,
and after filling a couple of holes and cleaning up the top channels i brushed it on. It turns the metal black like this.
I then went and bought an underseal probe and ghetto attached it to my weed killer pressurised spray bottle.
I diluted it with water ( you can dilute upto 50%) It meant i could then spray it inside the channels that i couldnt access so i can help stop whatever rust is in there and it would run down the seams and help stop the rust there too.
The next thing i started on was one of the brackets that the roof bolts down to the body, i forgot to take a photo of it on the van but here it is once i had cut it out.
I made up a cardboard template, cut it out and formed it then tacked it into place.
I then welded it all around. I decided to really take my time with this one. I need to have more patience with the welding so i done a few 10mm bursts then worked on something else whilst it cooled. Done a few more, let it cool, bit more let it cool etc... It seemed to have done the trick, once i ground the******away i was quite happy with how this section turned out.
I just need to drill a couple of holes and fix some nuts on it now.
I also started on the driver side upper channel. I was amazed to see that although the drivers side is a lot worse along the full length of the van than the passangers side , the channel was not so bad as the passangers?!?! The part that the gutter attaches to was quite rotten but the rest of it was ok. That was actually pretty good because i never really wanted to go through the hassle of making another complete panel. So i cut it out.
I then went over the inside with a wire brush and painted on the rust converter stuff inside. I cut a 19mm strip out of metal and tacked it to the bottom curved section first then to the top. This section really did try my patiance as its about 450mm long so having to start and stop all the time was annopying but it paid off (practise makes perfect).
I also feel quite happy about this repair, i still need to continue it forward and back but i need to fix those other sections first.
Thats all i got done for today. The good thing is, from the 16th of may i took a weeks holiday to get more done on the bodywork so expect a bigger update in the next fortnight.
38,780 PostsLatest Activity: Aug 05, 2026
