Kevbarlas1
Dec 18, 2011Explorer
Pokey2 wrote:
Hi Kev –
I have not read the entire 6 pages of this thread, but enough to be awed – no other word will do! - by what you have taken on and what you have done so far. And that you are capable of doing it all.
What I can’t help wondering is, what with holding a full-time job and doing all this work on the van, how on earth do you find the time to take all these photos, label them, take videos for U-Tube, and do the accompanying write-ups? My hat’s off to you!!
Ha, It can take quite a while to write up a decent post. Having to change the size of the images, then upload them and write up a decent story can take about 2 to 3 hours.
I write as i go because i enjoy it, helps me to keep track of what im doing and i imagine it will be cool to look back at this post in years to come. Robsouth - If you want to see a finished van then this is the wrong thread.
December update
Its been quite a busy month at work. One of the guys got made redundant so its put my work rate up a bit. Its also meant having to work late and help out on Saturdays, extra money so i cant really complain but its meant less time at the garage.
Last time I wrote I had just laid the roof on the table, ready to get cut up. I thought I would start on the front corners and work my way round the drivers side. The first thing i done was take the paint off around the edges of the roof to assess the metal work underneath.
This was the first corner I started on, It was the worst front corner so best to get it done and out of the way.
I flipped the roof over to take the surface rust off the inside edge too. You can see the cross brace i welded in to help it keep its shape when I removed it from the van.
This is the offending corner upside down.
The corners are a compound curve so that made shaping it a little bit more tricky. I did a lot of humming and hawing at it. Trying to figure out how to go around making a repair section for this part. I came up with a plan of cutting it out and making a basic template to work from. I haven't tried a compound curve repair before, so this probably isn't the right way but it worked for me.
No use for you anymore.
I taped a thin bit of cardboard to the area.
Then after a bit of snipping and more masking tape I had the rough shape mocked up.
Cut it out and I have my template.
I seem to have jumped a few steps ahead here. Basically I traced the template onto a sheet of 1.2mm and cut it out. I clamped a piece of 50x50 angle in the vice so that it was clamped in a V shape. I then used a round head hammer to tap a concave and trying it against the roof numerous times, using my hands to give it a final tweek and shape. I tacked it into place, i cut strips into it to help me with the stretching and shrinking principle.
Then all welded up when i was happy with it.
And a good dress up.
Yey! a complete corner, that wasn't as bad as I thought it would be.
The next again night i went back and started on the other corner. This one was in a bit better shape than the other.
Marked out, ready to get cut up.
I done this section in 2 patches, the mainly straight side and a tighter corner.
Tacked up and ready to weld.
*grind, grind, sand, clean*
Close enough to the opposite side for me.
I called it a night, looking forward to getting back to it again shortly.........
Unfortunately, the week before the caustic tank at my work burst. We use it to strip the paint off the old Cast fireplaces and radiators. Coincidentally, we have just got a lot of radiators needing done, quickly. The tank was made from plastic and had been repaired lots of times in its 20 year life span with Fiberglas so it was starting to look past its best. I checked out prices for other tanks big enough but the cheapest plastic one was pretty thin material and cost £1050. I thought it would be best to make a new one from scratch out of 3mm plate and 50mm angle. I was annoyed as it meant losing a weekend and a few nights on the van but it was actually good to do something different from the usual, a little bit of a challenge. I made it 8ft length, 45 inches tall and 2 foot wide. I gave it a lid and as it was metal i could add a heater. Caustics working properties increases tremendously when even a little bit of heat is added so i used a basic 27 inch central heating boiler coil. I also made sure to weld on a drain tap to this one, the plastic one had to be emptied via buckets and long waders, not fun. I added insulation to help with the heating and keep costs down.
Was really happy with how it turned out, lets see if this lasts 20 years.
I also had enough time to make a unique handle for my fiances boss's stove.
After the tank was done i had to miss a few nights at the garage to get the radiators done and ive just worked yesterday to give my boss a Saturday off ( he never gets them). So, back to today, the 18th.
Meet the newest addition to my growing garage stuff. This heater has been here since i moved in and its never been touched. I remember trying it out when i first moved in and it never worked so its been collecting dust ever since. Well since its now officially winter i thought id try to fix it. I changed the ignitor as it was looking quite duff but that never helped. I thought id service everything and that never helped, occasionally it would light up and go out, so id strip it all down again, try something new and it wouldn't work at all then it would etc.. After a lot of head scratching and time wasting i figured it wasn't making much pressure, all the seals were ok but on closer inspection to the back plate could see hairline cracks around the bolt mounts. I used soapy water to confirm my suspicions and yep, the back plate was knackered. All the air pressure was being lost. I ordered a new one and i thought id may aswell replace the filters. Since then its been great, works a treat and heats up the space fairly quickly with its 77,000 BTU rating. I'm using diesel to fuel it right now but will be moving onto paraffin when i get the time to get some as it burns cleaner and cheaper.
Enough of that crap. Back to the roof.
This is the drivers side, which was pretty bad all the way along. Oh, i forgot to mention. You may remember how i tried to make my own guttering which never worked very well and so i was left with 10 pieces of 50mm wide 1.2mm strips 4 foot long. They are now being put to good use as repair sections for the roof. Never through anything out, thats my motto! (probably got it from my dad).
I tried a couple of experiments before i got on with the roof, what would be the best way to put a curve on the strips. I tried the angle in the vice in a V shape first.
It kind of worked but I couldn't get enough pressure on it with the hammer so i flipped it around in the vice so the jaws pushed the tube into the angle.
That probably worked a bit too much, it did curve the strip but only in one place. The next idea was clamp the strip in 2 bits of angle and tap it around a piece of tubing. Like this :
This gave me the effect i was wanting, a nice gentle curve.
Back to the actual repairs, i forgot to take a photo of my first repair part. This piece of the roof held a hinge for the pop up roof and consequently had rusted a little higher up which required a bigger repair section.
New panel made up , i joggled all the top edges off the repairs to help with lining it up and clamping into place.
I done another repair after that and that was 3 sections all tacked up.
I was leaving to go home in the next hour so i thought id finish off this section.
The other difficult thing about the roof is trying to figure out far down the panel actually comes. The passenger side is pretty complete so ive used that as my reference and measured from the centre out and a bit of free hand to cut the edge off the panel.
A little before and after.
I then went home and had a nice roast beef and veg dinner, delicious.
The Christmas holidays are coming up soon which means i get a full week off. So with a little careful planing spending time with Jana and the van i should get more done. I would love the next update to be about the roof being attached back on atleast, we shall see.
38,780 PostsLatest Activity: Aug 05, 2026
