hotsparks
Apr 11, 2012Explorer
Hey Kevin where are you? :B
I was just checking for an update. I guess you are busy doing something which is better than being busy doing nothing. We are all still here following your project.
I was noticing you are starting to throw some primer paint on it. I think I remember you are using an "epoxy primer" is that correct? That's the best stuff there is. I know it is not cheap but it is the best. I have used hundreds of big cans of that stuff at work for painting large boats and small ships. You know you can put that paint on pretty thick and it will still dry as long as you have the two parts mixed. You can layer it on by two ways.
1- put the second coat on before the first coat has dried completely. You can paint the second coat when the first coat is just sort of not sticky to the touch. Maybe 2 hours dry time. Depends on how hot the weather is. Hot weather will make it dry faster. This way it bonds to the first coat without sanding.
2-The second way is to let the first coat dry completely for a day or longer. This will require you to scuff the first coat before painting the second coat. You can maybe use one of those green scuff pads or use some dry sand paper. If you let the first coat of paint dry completely without sanding, the second coat will not stick good to the first coat. That paint will dry hard as rock if you let it. Don't paint the second coat without sanding if the first coat is already dried.
There is a small window of time with that paint that you can either work it one way or you have to let it dry so you can work it a different way. After you use it for a while you will understand what I mean. I know, maybe you already understand what I mean, but maybe someone else can learn from this.
This paint is sometimes hard to find and is not usually sold to the public in those big box stores. Look for it at boating supply stores, and industrial paint suppliers. It must also be covered with some other type of paint because it does not hold up to UV light I think. It will get chalky after a while.
I bet the weather is getting warmer where you are, so that means your boss want's you to work more hours right? Keep up the good work, I give you credit. I'm sure you are going to finish this soon. But take you time and do it right the first time. Once you close this thing up you probably will not go back deep inside to change much. When you are done you will have a one of a kind R/V. I don't know how common those things are where you live but I've never even seen one over here. :B
38,780 PostsLatest Activity: Aug 05, 2026
